Re: HP 71B LE? Message #9 Posted by Namir on 19 Sept 2011, 11:29 a.m., in response to message #8 by Keith Midson
Keith,
You love that emulator especially when you configure the various ports to load more memory and the ROM files. Use the Edit | Port Configuration ... menu commands to bring up the Port Configuration dialog box. You can select the port using the list box located in the upper right corner of the dialog box. The Add button allows you to add a module to the port.
Loading the JPC ROM is especially nice because it extends the BASIC dialect allowing for better looping and decision-making structures than the bare BASIC of the machine. The additional constructs reduce the reliance of the code on line numbers or labels. The resulting code is easier to read and bit more up to par with structured languages.
Namir
Edited: 19 Sept 2011, 11:33 a.m.
