Needing more advice with my HP-48S Message #1 Posted by Palmer O. Hanson, Jr. on 18 Sept 2011, 10:18 p.m.
On 14 May I reported:
I left the cells in my 48S longer than I should have. One of the cells leaked. The leakage got into the foam that provides the spring for the cell contacts. The leakage dissolved (if that is the correct word) the adhesive that attached the cell contacts to the foam. I have cleaned the compartment and have demonstrated that the calculator still works by simply holding the contact against the foam while inserting the cells.
I think that some of the leakage is still in the foam. How can I remove the leakage safely? What adhesive should I use to attach the contact to the foam? If I replace the foam where do I find foam that does not deteriorate in a few years?
I now find that I have a new problem with my HP48S. If I press either the 2 or the 3 key the number 23 appears in the screen. Similar effects occur with the 5 and 6 keys, the 8 and 9 keys, and the . and SPC keys. Similar effects also occur with pairs of keys which are not part of the numeric keyboard. For example, if I enter 9 at level 2 and 2 at level 1 and press y^x I would expect to see 81, Instead I see 22.36159094 which indicates that the calculator took the square root of two and then raised 9 to the square root of two power. Similar effects appear with other adjacent pairs of keys such as EEX and DEL, etc.
If I place the calculator under a reading lamp for a couple of hours it will operate properly for a few minutes and then will return to the operation described above. I think this means that some of the cell leakage may have gone into the electronics compartment, perhaps under the keyboard. This is certainly possible since the cell compartment is not a bathtub as was the case with the HP-35, HP-45 and HP-80. So, my questions are:
How do I open the the device to inspect for cell leakage and to clean if necessary?
Or, am I better off simply keeping the calculator warm?
