HP-15C LE emulator skin change issue Message #1 Posted by M. Joury on 12 Sept 2011, 8:49 p.m.
Could someone that has the emulator installed please verify if they have a problem changing the calculator skin? If I change to a different size the window does not repaint correctly. I have to stop and restart the application and then all is fine.
I am running the emulator under Windows 7 Professional.
Thanks,
-Marwan
