Re: Degrees conversion for trigonometric function Message #2 Posted by Dieter on 30 Aug 2011, 3:16 p.m., in response to message #1 by Beth Snipes
The "c" tells you you're in complex mode. Here all angles are assumed to be in radians, as usual. So simply turn complex mode off. This is done by clearing flag 8. Press [g] [CF] [8]. CF is the blue-shifted function of the "5" key.
Generally, the angular mode is set by using the DEG RAD and GRD mode functions (blue-shifted functions of the "7", "8" and "9" keys).
Dieter
