Strange HP-10 Printer behavior Message #1 Posted by aj04062 on 30 Aug 2011, 6:08 a.m.
Can anyone steer me in the right direction to correct this behavior?
At the beginning of the strip the battery was nearly dead, but the printer seemed to work fine. So I charged the batteries overnight. When I tried again, I get the solid lines across diagonally as the paper advances then across again. It doesn't stop until I turn off the calculator.
If I plug the calculator BACK IN, it works correctly. See correct prints midway.
