Re: So what will a 15C LE be like? Message #28 Posted by Lincoln R. on 19 Aug 2011, 9:21 p.m., in response to message #27 by Paul Gaster
Probably not possible, the 35S was 6502 based, and the 15C LE will almost certainly be Atmel ARM. Also, I believe the 35S's software was written by Kinpo (the company that was making HP's calcs at the time) and not by HP.
I honestly suspect it will be a new style 12C with different labels and firmware. The modern 12C apparently emulates a Voyager chipset on an ARM, IIRC the displays in Voyagers were the same or quite similar, so HP has little development cost in this other than tracking down the original 15C ROM and getting it to run in the existing emulation, and having their manufacturing contractor (I think they've mostly been using Inventec lately) print different key labels.
For that matter (and here's a real pipe dream), this architecture would make it trivial to build new 16Cs.
