WP 34S Assembler bug fix and doc update Message #1 Posted by Neil Hamilton (Ottawa) on 26 July 2011, 6:08 a.m.
Bug fixed in assembler when using output of disassembly with specified opcode tables ('-opcodes' switch). It emitted a "#" as a comment marker instead of the accepted "//" causing the disassembled output to not be directly re-accepted by the assembler.
SVN documentation updated with several typos fixed in the same area (section 5.2). As well, you can find a 'diff' version at:
http://web.ncf.ca/njsdham/wp34s/doc/WP34s_Assembler_Disassembler_diff_9Jul2011_to_26Jul2011.pdf
Regards...
