HP Forum Archive 20
Card reader bug
Message #1 Posted by Eric Smith on 24 July 2011, 6:47 a.m.
There is a card reader bug that is present in the 1E version of the card reader (and probably 1D), and fixed in the 1G version. I haven't got a 1D or 1F to check. I discovered the bug around 1981, and I think I saw it mentioned by someone else in the PPC Journal at one point.
With the card reader plugged in, press the key sequence
GTO . EEX 0 0 backspace backspace
What you should see after that is
GTO .1__
If you have the bug, the display rotates so it reads
0      GTO .1
From study of a instruction trace, it appears that the bug is due to the card reader ROM's I/O service poll routine violating one of the requirements of the mainframe polling code. From the mainframe source code:
All subroutine levels are available except in I/O service entry. If PKSEQ is set then I/O service routines must either preserve three subroutine returns on the subroutine stack or else terminate the partial key sequence.
The CR-1E I/O service poll code uses two levels of subroutines. Perhaps the CR-1G ROM was changed to not need two levels of subroutines, though I haven't yet disassembled the code to determine what the actual changes are.
Re: Card reader bug
Message #2 Posted by Les Bell on 24 July 2011, 7:02 a.m.,
in response to message #1 by Eric Smith
Hi, Eric,
Mine has the bug, but how can I tell which version it is?
The serial number is 2036S45246, if that's any indication.
Best,
--- Les
[http://www.lesbell.com.au]
Re: Card reader bug
Message #3 Posted by Geoff Quickfall on 24 July 2011, 8:42 a.m.,
in response to message #2 by Les Bell
I have about 5 of these, let me check. Four on the table being restored as we speak.
Version is seen by catalog function.
Geoff
Re: Card reader bug
Message #4 Posted by Les Bell on 24 July 2011, 9:02 a.m.,
in response to message #3 by Geoff Quickfall
Mine just says "CARD READER", Geoff - no version number at all.
Best,
--- Les
Re: Card reader bug
Message #5 Posted by Eric Smith on 24 July 2011, 3:11 p.m.,
in response to message #4 by Les Bell
Without a version letter in the catalog, it is probably 1D. I haven't heard of anyone finding the earlier versions, so 1A-1C were probably only in prototypes.
If you really want to check, you can use the diagnostic ROM's ROM check, which will display the full identifier, or you can use the ZenROM or other means to look at ROM locations EFFB through EFFE.
Re: Card reader bug
Message #6 Posted by Ángel Martin on 25 July 2011, 6:08 a.m.,
in response to message #5 by Eric Smith
Function PGTRAIL in the TOOLBOX-II module (and others) will show the last four words before the checksum (a.k.a. the "page trail"). Input is the page#, 0-15.
Re: Card reader bug
Message #7 Posted by Les Bell on 25 July 2011, 6:15 a.m.,
I don't have those ROM's, but comparing with Geoff's serial number list, I'd say it's a 1D.
Best,
--- Les
Re: Card reader bug
Message #8 Posted by Geoff quickfall on 24 July 2011, 3:01 p.m.,
I have a 1E, 1F, 1G and three that state Card Reader only:
display version serial number
CARD RDR 1E 2056S46900 CARD RDR 1F 2319S81056 CARD RDR 1G 2703S80162 CARD READER ?? 2044S45132 CARD READER ?? 2023A00100 CARD READER ?? 1935A00179
It would seem that the early card readers just state "CARD READER" with a CAT II display.
I will check the bug on 1F and I think Wlodeks book mentions it in the bug section.
Cheers, Geoff
