Re: WP34S 956 crashing in wine Message #3 Posted by Neil Hamilton (Ottawa) on 25 May 2011, 7:00 a.m., in response to message #2 by Marcus von Cube, Germany
As suggested, I deleted all the copies of wp34s.dat in the tree (there were several so I suspect that it saves this file out to whatever directory I launched from). Still no luck.
I poked around a few other revision to see what would happen. If I wind back to 954 (svn up -r 954), everything works fine. However, 955 crashes in the same manner as 956.
Thanks for the svn wisdom. I'll admit that I am much more familiar with cvs than svn. Your suggestion is certainly much shorter. I was just using what was documented on the sourceforge website (your know: if it ain't broke, ... you're not trying hard enough :-) ).
Thanks...
