Re: matrix element operation Message #8 Posted by Oliver Unter Ecker on 22 May 2011, 6:00 a.m., in response to message #1 by Sok-khieng Chum Hun
Not regarding the devices you ask, but probably still helpful:
On ND1, an iOS app with a feature set that closely resembles a 50g without CAS but with other additions (incl. programmability in RPL+ and JavaScript), "lists" and "vectors" are unified, and [1 2 3] [2 3 4] * will return [2 6 12].
"+", "-", "1/x" and all single-valued operators and functions (such as "sin", "!", "loggamma", ...(a list of >100)) work on both real and symbolic vectors.
This also works with large vectors (of, say, 10^5 elements).
The DOLIST and DOSUBS techniques mentioned also work, and, as on the 48 and 50g, can be used on more than two vectors at once.
48, 50g, ND1 have other vector-processing type functionality, btw, sometimes hiding under unusual names. The common "fold" operation is known as STREAM, for example.
