Re: wp34s stability update Message #2 Posted by Jeff O. on 21 Apr 2011, 3:04 p.m., in response to message #1 by Marcus von Cube, Germany
I would not call myself educated, but it seems stable to me. The only program I have entered is as follows:
001: LBL A
002: 1
003: +
004: GTO A
005: RTN
If I let the above run for 60 seconds, both the 20b and 30b on which I am loading each version of the ROM count up to about 170,000.
I noticed that the BATT command returns 3.0 on both the 20b and 30b. A couple versions ago, I was getting 2.9 on the 20b and 2.8 on the 30b. I did not change batteries, so I was curious if this function has changed.
On the 30b, I noticed that when I turn it off the "Bye..." message appears only fleetingly, while on the 20b the message appears for a brief time (maybe 0.5 second?) and then the display fades away. Is there a hardware difference which causes this?
