Re: HP 20b/30b programming cable eats on batteries! Message #4 Posted by gene wright on 18 Apr 2011, 4:27 p.m., in response to message #3 by Marcus von Cube, Germany
For example, the Revision 685 calc.bin file has this as its comment: "Turn of flash memory while idle"
which probably says turns off flash memory when idle.
But... is it a stable build? is it worth loading? Or should I load for real testing Revision 673 from Sunday?
That's the only reason I thought to ask you to note on the builds if it is a partial "I fixed X but haven't looked at Y" build or "Hey, this is a pretty solid build and you can use this to load your 34s" build.
Sorry for causing trouble...
