Re: dealing with 20b/30b/wp34s power drain Message #3 Posted by hugh steers on 18 Apr 2011, 2:25 p.m., in response to message #2 by Walter B
more seriously, i do think HP should consider a model with a slightly thicker part to accommodate maybe AAA batteries.
This would give a much extended battery life, could afford to run the processor faster on average, plus it could provide the current to drive a micro SD card slot.
my hack shown in the pictures is the result of some goose chase regarding weak button batteries. basically, i had a situation where the unit did flash, but drained the battery whilst doing so to the point that it wouldnt operate the unit. i thought i'd bricked it until i tried driving from a psu.
incidentally, im thinking the WP34s rom requires more current to run, since a weak battery wouldnt activate it, but the same battery worked in another unit. something to watch out for.
-- hugh.
