Re: HP75D AT&T Version Message #3 Posted by Jeff O. on 18 Apr 2011, 8:21 a.m., in response to message #1 by Alberto Fenini
In case you have not connected with John, and/or for anyone else who needs to know, here is how to remove the pod:
How to Remove Pod from HP-75D:
Turn the pod upside-down and you'll see various philips screws. Unscrew the 6 large ones (3 on either side of the pod). Then you can take away the two side-panels which hold the HP75 in place. Gently lift the HP75 and you'll see that the port-plug is connected with a flex-cable. Unplug the HP75 and there you are. A common problem is that HP75 which come in a pod don't have the battery door to run them independently.
Above is not my own, is courtesy of Daniel (last name not known by me), probably from this Forum.
I needed the instructions for the exact same reason you do, to remove the pod from ATT-branded 75D's. I found four of them at a Hamvention seven or eight years ago. I think one or two of them worked (they were wet, having been exposed to rain.) I never found any information on what ATT did with them.
