Re: 30B/34s - adding more RAM Message #5 Posted by robert rozee on 12 Apr 2011, 11:11 a.m., in response to message #4 by Tim Wessman
The 10bII+ screen is only using some 130 or so of the available pixels, so unless you want even less information it isn't ideal.
Also, why use RAM when flash will use less power overall?
flash has a limited (though admittedly large) lifetime wrt write cycles, and will consume more peak current (i'm assuming) when carrying out these writes. in a device powered by a couple of button-cells, any operation that draws a higher than average current, even for a short duration, is of concern - one may end up in the embarrassing situation where the cells fail to have enough 'oomph' to ride through the flash writes long before they are otherwise exhausted. and a failed write flash will lead to... corrupted contents. a bad thing in anyone's books.
the down side of SRAM is the backup current, but for the OnSemi devices this is a somewhat negligible 1uA maximum. assuming a very conservative 30mAh of total capacity, this would be good for nearly 3 1/2 years of backup.
the 12-digit 7-segment display is no worse than that of the hp-15c, which is only 10 digits. and the 10bII+ also has more keys (40) available than the 20b/30b (only 36). hmmm, as i write this i am thinking, "will we see an hp-15cII+ released in the same format/case as the 10bII+?".
