Re: HP-71B slower with HP-IL Message #2 Posted by Eric Smith on 7 Apr 2011, 5:32 a.m., in response to message #1 by scalpa49
Yes. The HP-71B is trying to communicate on the HP-IL loop, and failing due to the lack of a loop. If you're not using any HP-IL devices, either connect a cable directly between the two ports, or give an "OFF IO" command.
If you use "OFF IO", to reenable I/O you use the "RESTORE IO" command. It always seemed to me that it should be "ON IO", but that doesn't work.
