Re: [] operator Message #12 Posted by Oliver Unter Ecker on 4 Apr 2011, 8:16 p.m., in response to message #11 by David Hayden
David,
The overall structure of both cases is
array[something]
In case A, "something" is RPL.
In case B, "something" is an algebraic expression without quotes.
Each case gives two examples.
I'm getting an "invalid syntax" error if I try to place brackets inside an expression, so 'partitions[pents[k] + 2]' does not work for me (on an HP-49).
Maybe you mean 'partitions(pents(k) + 2)'?
Yes, case B
would indeed be equivalent to
'partitions(pents(k) + 2)' EVAL
Thanks for pointing this out. This should make the syntax look friendlier in RPL eyes. I know the lack of quotes may be weird. But the proposed syntax is equivalent to the one in C-like languages.
(Conversely, the expression syntax, what with having "()"s, needing quotes, and an EVAL, is probably very weird from the point of view of most other languages.)
Unsurprisingly, this
\<< [1 2 3] \-> x \<< 1. 1000. START 'x(1)' EVAL DROP NEXT \>>
runs 6.5x slower than this
\<< [1 2 3] \-> x \<< 1. 1000. START x 1 GET DROP NEXT \>>
on Emu-48/HP-49.
So, using expressions instead of GET for array access seems unfeasible. But, again, thank you for pointing out that my proposed syntax B looks almost like the whole thing wrapped in an expression.
> partitions [1]
This one is easy. The proposed operators are "fused": they *must* be connected to the name of a local. No white-space inbetween allowed. So, your example has the regular meaning.
Only
partitions[1]
would be the new thing.
If you try to enter "partitions[1]" on an HP-calc you get "partitions [ 1 ]" on the stack, so that wouldn't work. But, then, RPL+ is not meant to (or, rather, cannot) be retro-fitted to existing HP calcs.
Thanks for feeding in!
Edited: 5 Apr 2011, 6:13 a.m.
