Re: HP 25 Battery Cover Stuck? Message #5 Posted by Randy on 2 Apr 2011, 8:33 p.m., in response to message #4 by Michael de Estrada
Pop out the top two rubber feet and remove the two Phillips screws underneath. Now, with the same Phillips you removed the screws with, push on either one of the two charger input pins and push the keyboard assembly out at the top. Now you can lift the electronics up and out leaving you with the battery and case back as one piece. Once that is complete, you can easily remove the battery.
Edited: 2 Apr 2011, 8:34 p.m.
