Symbolic Complex Linear System Solver (HP-28S, HP-48G/GX and HP-50g) Message #1 Posted by Gerson W. Barbosa on 13 Mar 2011, 3:10 p.m.
This program was written many years ago by Francisco Matheus, one of my classmates back then, originally for the HP-28S. It was particularly useful during Circuit Analysis examinations. The program would accept symbolic equations, no further rearrangement being necessary, which was very impressive.
The author has authorized its free use with the hope it continues to be useful for EE students. No warranty shall be provided though. Test it on your textbook examples before you decide it's suitable for your needs. The HP-48G/GX and HP-50g built-in linear system solver is an option.
1) V1 - V2 = 10*Ix
2) V1/j20 + (V1 - V3)/20 + V2/10 + (V2 - V3)/-j10 = 0
3) V3/j10 + (V3-V2)/-j10 + 2/-45 + (V3 - V1)/20 = 0
4) Ix = -V3/j10
where j = sqrt(-1) and 2/-45 is 2 angle -45 degrees.
As an example, the equations in the linear system above would be entered as
'V1-V2=10*IX'
'V1/(0,20)+(V1-V3)/20+V2/10+(V2-V3)/(0,-10)=0'
'V3/(0,10)+(V3-V2)/(0,-10)+(1.41421356237,-1.41421356237)+(V3-V1)/20=0'
'IX=-V3/(0,10)'
On the HP-28S 2/-45 would have to be previously converted from polar to retangular coordinates. Notice the number of equations could have been reduced to three by substituting eq. 4 in eq. 1, but we'll use the example as it has been presented.
Copy the programs to an empty HP-28S directory. Enter the four equations of the example system, enter the list of unknowns {V1 V2 V3 IX} then run SYS program to solve the linear system. The '<-' program cleans up the directory, that is, it purges all objects at the left of it in the menu.
The lines below can be copied and pasted to Emu42 with an HP-28S ROM and then saved to 'SYS', '<-' and 'EQS', respectively, after applying the STR-> command. ( '<-' should be entered as 142 CHR STR-> )
’ DUP SIZE ¨ l n
’ n ¨LIST 'EQS'
STO 0 n
FOR i 1 n
FOR j i j == 1
0 IFTE l j GET STO
NEXT 1 n
FOR j 'EQS(j)'
¨NUM
NEXT n ¨ARRY i
IF NOT
THEN NEG 'VET'
STO
ELSE VET +
ARRY¨ DROP
END
NEXT { n n }
¨ARRY l PURGE TRN
CONJ 'MAT' STO VET
MAT / n 1
FOR i DUP i GET
l i GET STO -1
STEP VET ARRY¨
DROP { n 1 } ¨ARRY
'VET' STO DROP
’ VARS 1 OVER 'ˇ'
POS 1 - SUB PURGE
{ 'V1-V2=10*IX' 'V1/
0' 'V3/(0,10)+(V3-V2
)/(0,-10)+
+(V3-V1)/20=0' 'IX=-
V3/(0,10)' }
Contents of the directory after the example linear system is solved
HP-28S Version:
V1 (-1.88561808316,
-24.5130350811)
V2 (-1.88561808316,
-5.65685424948)
V3 (-18.8561808316,0)
IX (0,-1.88561808316)
MAT
[[ (1,0) (-1,0) (0,0) (-10,0) ]
[ (.05,-.05) (.1,.1) (-.05,-.1) (0,0) ]
[ (-.05,0) (0,-.1) (.05,0) (0,0) ]
[ (0,0) (0,0) (0,-.1) (1,0) ]]
VET
[[ (0,0) ]
[ (0,0) ]
[ (-1.41421356237,1.41421356237) ]
[ (0,0) ]]
EQS { 'V1-V2=10*IX' 'V1/
)/(0,-10)+
V3/(0,10)' }
« VARS 1 OVER '<-'
POS 1 - SUB PURGE
SYS
« DUP SIZE \-> l n
« n \->LIST 'EQS'
STO 0 n
FOR i 1 n
FOR j i j == 1
0 IFTE l j GET STO
NEXT 1 n
FOR j 'EQS(j)'
\->NUM
NEXT n \->ARRY i
IF NOT
THEN NEG 'VET'
STO
ELSE VET +
ARRY\-> DROP
END
NEXT { n n }
\->ARRY l PURGE TRN
CONJ 'MAT' STO VET
MAT / n 1
FOR i DUP i GET
l i GET STO -1
STEP VET ARRY\->
DROP { n 1 } \->ARRY
'VET' STO DROP
HP-48G/GX Version:
On the HP-48G/GX and the HP-50g, the third equation can be entered as
'V3/(0,10)+(V3-V2)/(0,-10)+(2,/-45)+(V3-V1)/20=0'
On the HP-48G/GX the angle symbol '/ ' is accessible through right-shift SPC (ALPHA right-shift 6 on the HP-50g).
%%HP: T(3)A(D)F(.);
DIR
V1 (-1.88561808316,-24.5130350811)
V2 (-1.88561808316,-5.65685424948)
MAT
[[ (1,0) (-1,0) (0,0) (-10,0) (0,0) ]
[ (.05,-.05) (.1,.1) (-.05,-.1) (0,0) (0,0) ]
[ (-.05,0) (0,-.1) (.05,0) (0,0) (-1.41421356237,1.41421356237) ]
[ (0,0) (0,0) (0,-.1) (1,0) (0,0) ]]
EQS { 'V1-V2=10*IX' 'V1/(0,20)+(V1-V3)/20+V2/10+(V2-V3)/(0,-10)=0' 'V3/(0,10)+(V3-V2)/(0,-10)+(1.41421356237,-1.41421356237)+(V3-V1)/20=0' 'IX=-V3/(0,10)' }
\183\<-
\<< VARS 1 OVER '\183\<-' POS 1 - SUB PURGE
SYS
\<< DUP SIZE \-> l n
\<< n \->LIST 'EQS' STO 0 n
FOR i 1 n
FOR j i j == 1 0 IFTE l j GET STO
NEXT 1 n
FOR j 'EQS(j)' \->NUM
NEXT n \->ARRY i
IF NOT
THEN NEG 'VET' STO
ELSE VET + ARRY\-> DROP
END
NEXT { n n } \->ARRY l PURGE TRN CONJ 'MAT' STO VET MAT / n 1
FOR i DUP i GET l i GET STO -1
STEP DROP MAT VET n 1 + COL+ 'MAT' STO 'VET' PURGE
END
HP-50g Version:
CAS mode should be set to Complex.
%%HP: T(3)A(D)F(.);
DIR
V2 (-1.88561808317,-5.65685424948)
V3 (-18.8561808316,0.)
IX (0.,-1.88561808316)
MAT
[[ (1.,0.) (-1.,0.) (0.,0.) (-10.,0.) 0. ]
[ (.05,-.05) (.1,.1) (-.05,-.1) (0.,0.) (0.,0.) ]
[ (-.05,0.) (0.,-.1) (.05,0.) (0.,0.) (-1.41421356237,1.41421356237) ]
[ (0.,0.) (0.,0.) (0.,-.1) (1.,0.) (0.,0.) ]]
EQS { 'V1-V2=10*IX' 'V1/(0+20*i)+(V1-V3)/20+V2/10+(V2-V3)/(0+-10*i)=0' 'V3/(0+10*i)+(V3-V2)/(0+-10*i)+(2*COS(-45)+2*SIN(-45)*i)+(V3-V1)/20=0' 'IX=-V3/(0+10*i)' }
\183\<-
SYS
FOR i 1 n
NEXT 1 n
NEXT n \->ARRY i
IF NOT
THEN \->NUM NEG 'VET' STO
ELSE VET + \->NUM ARRY\-> DROP
END
NEXT { n n } \->ARRY l PURGE TRAN 'MAT' STO VET MAT / n 1
END
Edited: 13 Mar 2011, 4:00 p.m.
