9100A with no display Message #1 Posted by Richard Wilder on 3 Jan 2011, 12:58 a.m.
Hi Group!
I recently got a 9100A into my lab for repair. Symptom is no display. So far I've verified all supply voltages, fuses are all OK, the register display lights come on but the error light doesn't come on with the RUN switch set, pressed STOP, STOP, 1, CHS, SQRT. The error lamp tests OK. I downloaded Tony Duell's incredible schematics for the A model and have tested the display board signals and all the FF outputs with the following results. At this point I don't know which FF's should be toggling. I've also tested all the main ROM and control ROM outputs and I can post those results if anybody thinks that might be usefull. For now here are the FF states. Any assistance troubleshooting this vintage machine would be greatly appreciated! ;^)
9100A
Symptom: No display
Fuses: OK
Register illumination lights: Light
-15V, 220V & 3500V all OK
RUN mode, press STOP,STOP,1,CHS,SQRT: No error light, lamp tests OK
On the Vertical amp board:
ZDHD and ZDRD signals are OK, ZDMV and ZDRV are no signal
On the Horizontal amp board:
ZDHL is ON, all of ZDRL, ZDSL, HDRR, ZDFO are no signal
ZACE (blanking) on the gating board is stuck high (0V) (crt trace blanked)
Checked FF's on the TP connectors:
(0 = -V, 1 = 0V, T = toggling)
LH FF CKT STATE
F1 ROMA8' T
F2 ROMA7' T
F3 ROMA6' T
F4 ROMA5' T
F5 ROMA4' 0
F6 ROMA3' 0
F7 ROMA2' 0
F8 ROMA1' T
F9 ROMA0' 0
F10 F50 0
F11 F51 T
F12 F52 1
F13 F53 1
F14 F54 0
F15 BADDRA' 1
F16 BADDRB' 1
F17 BADDRC' T
F18 BADDRD' T
F19 BADDRE' T
F20 BADDRF' T
RH FF CKT STATE
F1 F25 0
F2 F24 T
F3 F23 T
F4 F22 T
F5 F21 T
F6 F20 T
F7 F30 T
F8 F31 T
F9 F32 T
F10 F33 T
F11 F34 1
F12 F73 T
F13 F72 T
F14 F71 T
F15 F70 T
F16 F40 T
F17 F41 T
F18 F42 1
F19 F43 1
F20 F44 1
