Re: NoVRAM / HEPAX MCODE Question Message #3 Posted by Frido Bohn on 6 Dec 2010, 5:01 a.m., in response to message #1 by Jeff Davis
Hi Jeff,
It is possible to allocate HEPAX memory for other purposes, such as for ROM-creation.
Basically, you have to change the word at address xFF3 to 300h using HEXEDIT, were x denotes one of the pages 8–B. Then, addresses xFE7 and xFE8 have to be 000h. A detailed description can be found in the HEPAX manual Vol. 1, p. 63.
A neat example how to program a user-developed ROM can be found in the HEPAX manual Vol. 2, p. 153.
What Geir described above is the way how to copy the programmed ROM into Page F via ram2rom into the Nov64 system where Page F usually must be flashed, I believe. Thus, it would be the next step after you did your ROM programming.
Best regards
Frido
