Re: HP-41 MCODE: System calls - a cataloged/priotitized list? Message #8 Posted by 聲gel Martin on 29 Nov 2010, 10:15 a.m., in response to message #6 by Raymond Del Tondo
Aren't you following a false vector here? What good is to have all the entry point names and locations if you don't have the documentation for them?
Here's what I did: disassemble the CX OS using the MLDL2k manager, transfer the text result into Excel, then trace the entry points identified by this process matching them back with the VASM ducuments, then provide an hyperlink to go back-and-forth as required. I use Excel but the same could be done with other vehicle (pdf, for instance).
This "project" is not complete. I finalized ROM0, and ROM2, still working on ROM1. More difficult is the stuff in ROM3 and ROM5 (both banks), as they're not documented in the older VASMs - and neither in MLDL2k manager.
I think this could be the core for an open, Wipi-like, community effort to complete them and add more information as we go...
Just a though.
PS. Look at the LABELS ROM documentation for what you're after...
