Re: Deteriorating pouch (case) Message #11 Posted by Martin Pinckney on 25 Nov 2010, 9:23 p.m., in response to message #1 by Ernst Fueloep
I don't have any older HP's with the style of case you refer to, but I assume this is a foam rubber lining that is deteriorating.
This seems to be a common problem with foam on old equipment. I have had this happen with many camera-related cases from the 1970's and 80's. Not only foam, but the leatherette cases seem to get to a certain age, and then crack and crumble, or turn gooey, like the infamous card reader rollers.
I have often wondered if this is environment-related or just age.
Interestingly, just recently the headliner in my (Dodge) truck began to droop. I found there was a thin foam pad above the fabric, and it was crumbling. Now the truck is only six years old.
When I took it to the auto trim shop, the guy indicated it was a common problem. He said the factory foam "has oil in it," but his replacement material does not.
