Re: Cell types for Pioneers Message #2 Posted by Dieter on 16 Nov 2010, 8:34 a.m., in response to message #1 by Martin Pinckney
I assume we're talking about a certain battery size with
the dimensions 11,6 x 5,4 mm that, for example, is knows as
- LR44, A76, 357, A13, ... as an alkaline cell
- SR44, S76, V76PX, ... in its silver oxide version.
Mercury cells are no longer available. Both in the US and in Europe they have been banned for environmental reasons. Technically, there were great (constant voltage, very high capacity per volume unit).
A look at the manufacturers' technical specs shows the two
main differences between alkaline and silver oxide batteries:
capacity and voltage. On average, a LR/SR44-sized "silver cell"
has roughly 50% more capacity ("more than 100 mAh" compared to
"more than 150 mAh") and a higher average voltage that also
drops very slowly.
I have several Pioneers in regular use, so I have to feed them fairly often. Does anyone have any data (as opposed to opinion) on the practical cost comparison (that is, in use) of silver vs. alkaline?
It looks like silver costs about 2.3X alkaline.
So the question is, even though I know silver lasts longer, are they cheaper in net cost, or alkaline?
Well... since there is an extremely wide price range,
all you can say is that both (!) battery types may cost
"some cents" as well as "some EUR/USD". For instance, over here in
Europe we have those "One-Euro-Shops" where you can get (almost) everything they carry for one Euro. Including battery sets
with ten or more different coin cells, three or five of which
are usually LR44s. Of course I wouldn't expect the same battery life
as a quality cell from a major brand, bought in an electronics or photo store for, say, 3 or 5 EUR/USD, but I don't think the question
whether to choose an alkaline or a silver oxide cell can be boiled
down to a factor 2,3. :-)
For my part, I almost exclusively use higher capacity cells, so in this case I would choose the silver oxide version. They last significantly longer and I don't think a few more cents really make a difference.
Dieter
