HEPAX manual Vol. 2 reprint. Message #1 Posted by Diego Diaz on 18 Aug 2010, 11:00 p.m.
Hi all,
I've been heavily using the copy of the HEPAX manual, and found it useful to develop my NoV's project.
However, the available copy is not very handy since it's just a scanned image.
So I've taken the time to rebuild the volume 2 (the one I use more often) and think it may be of interest to some of you.
Thanks to Ángel Martín for providing the scanned images of the covers.
The PDF file is available here.
I've tried to make it as accurate as possible, including the addendum errata, as well as correcting some known errors in the original print. Anyhow, some OCR errors may have found their path into the PDF file. Please notify if you find any.
A couple of Appendices have been removed since they are not useful any longer: "Warranty and service information" & "Addresses of User groups"
Best wishes from Spain.
Diego.
P.S. I don't use the volume 1 very often, however, if there is a general interest in having it also reprinted. I can do it (just allow a few weeks, it's a time consuming task... ;-) A good quality scan of the pictures on module insertion/extraction will also be welcome for the volume 1... :-)
Edited: 18 Aug 2010, 11:07 p.m.
