ADV or STD HEPAX? Message #1 Posted by Diego Diaz on 30 July 2010, 6:44 p.m.
Hi all,
I'm trying to restore an HEPAX module to its better day's splendor... :-)
The poor little thing arrived in a very bad state.
See pics:
Seems that someone has attempted sort of repair with little success.
It also seems that back in the late 80's silicon glue must be considered the coolest thing on earth! (what a mess) :-(
Ok, the silicon glue has been removed, the connector solders have been reworked and the RAM chip replaced (the original one had one broken pin, thus the tiny wire in the second PIC).
I need some help from those which may have pictures (or may take them) form HEPAX chip (MB671209U) both from STD and ADV HEPAX.
The question comes from the fact that the rebuilt HEPAX above arrived into an "ADV HEPAX" labelled shell, however, once rebuilt it shows only two pages of HEPAX RAM.
Also both port-detecting lines (B3 & B4) are connected to the HEPAX chip. Advanced HEPAX only needs B4.
But, to make things a little bit more confuse, the module shows up in CAT 2 as "HEPAX 1D".
Possibilities:
- Module is a late (ver 1D) STD HEPAX, and it was placed into the wrong shell.
- Module is an ADV HEPAX with a faulty address line, thus the lack of two RAM pages.
Questions:
Are there different chips for STD and ADV HEPAX?
Does someone have pictures to clarify this doubt?
Test which can also help:
With ADV HEPAX inserted into port 2, [<-] [ON] (perform memory lost)*, then execute "HEPAX 002" and check which page is HEPAX 1D using. Try with ports 4, 3 and 1.
*NOTE: [ENTER] [ON] [ON], may also work without losing main memory contents.
Any help will be very welcome.
"clonix41(at)gmail(dot)com" in case you can't place pictures in the forum.
Thanks and best wishes for the summer... ;-)
Diego.
