HP 67 card reader error Message #1 Posted by Mark Puscas on 11 July 2010, 9:06 p.m.
Looking for any troubleshooting suggestions...
Recently got an HP-67, disassembled it, cleaned it, repaired gummy wheel (thanks to reading the forums on this site!); everything seems to work fine mechanically, but magnetic cards all give me an "error" reading. I've tried pre-programmed cards, blank cards, all give the same "error" message. I've tried writing to cards, and that seems to work (although no way to verify). I re-opened calculator, verified all the little white balls in place, white roller pin in place, gold weird-shaped contact switch is well-positioned, cleaned the read/write head (several times), all to no avail.
Any suggestions?
Mark
by the way, for the gummy wheel repair I got a 2 foot length of Du-Bro #222 Silicone fuel line tubing, purchased at a local shop that caters to remote controlled cars/planes. Fit and worked perfectly!
