16C display problem Message #1 Posted by John Robinson on 7 June 2010, 7:45 a.m.
Hi All, I have a 16C which had a leaky display, so I bought a 12c of the same vintage (1984) as a display donor. The 12c display was working perfectly, so I swapped out the 16c old display for the new 12c display, and after various attempts I have it working as best I can. However, one segment in one digit refuses to work.
I would have though these displays would be multiplexed, so if one segment doesn't work, then that same segment in all digits would not work. I have counted the number of contact pads for the siplay to be 57, which would not be enough to individually address all 7 segments and decimal point for 10 digits and annunciators etc, so I figure it must be multiplexed.
Can anyone help me to sort out this problem please ?
Thanks
