Re: HP 50g PARTFRAC, INTVX Error/Problem Message #2 Posted by Bart (UK) on 1 June 2010, 4:27 a.m., in response to message #1 by Sean Kane
Hi Sean,
First, in the manual the equation is not the same as used in the screen shots, the last term in the denominator is X^2. Mine works as shown in the screen shots.
Make sure you do not have a variable X defined in the VAR menu (or whatever variable you are integrating with respect to otherwise the symbolic integrator will attemp to use it).
Try resetting the CAS to the defaults: To return the CAS to its default state, press "right shift" followed
by SYMB (CAT), ALPHA F3(C), DOWN cursor. With CASCFG selected, press ENTER.
OR by typing CASCFG (double press "ALPHA" to lock ALPHA mode) on the
command line followed by ENTER.
See also the HP help forum for Calculators:
HP Calculator help forum
HTH Bart
