Re: Voyager display swapping - any advice ? Message #6 Posted by Vieira, Luiz C. (Brazil) on 28 May 2010, 11:04 a.m., in response to message #2 by Bart (UK)
Hi;
AFAIK, all 1.5V, LR44-like, 3-cell Voyager EXCEPT some new HP12Cīs use the same LCD and they all share the same status indicators (only the HP12C Platinum has fewer indicators). Should check if the HP12C you are using as a donor has one of the two possible, compatible inside layout. If you open the two calculators and they either have a small flex-circuit assembly with the LCD and all electronics OR a one-piece MB with two ICīs, the LCDīs are interchangeable. If the HP12C has a PCB with provision for one single IC, I cannot tell the same.
Can you post a picture of the two calculators so we can evaluate it better?
Cheers.
Luiz (Brazil)
