Re: HP-41 Programs Message #28 Posted by HrastProgrammer on 11 May 2010, 1:11 p.m., in response to message #27 by Bill Zimmerly
Quote: Egan Ford's Article on 41C to 50G Migration
Wow, it must be a loooooong time since the last time I have been here, because I didn't know about this article until today. And even much longer time since I finished my work on HP-41E ...
Anyway, with a 2-year delay, congratulations to Egan for making such a comprehensive and useful article!
Just one small correction ... If you store some of those code objects (containing various HP-41E variants) to a variable in the main RAM, you won't get MEMORY LOST after you exit the emulator with ON&F and run it again, no matter if RAM saving has been enabled or not. This is because the whole RAM has been preserved inside the emulator body. You can even copy such code objects from one calculator to another and emulator RAM will be preserved.
Of course, if you store it to a SD card on HP-50G, then you'll get MEMORY LOST each time, because the emulator has to be temporarily copied from SD to main RAM for execution. So, in this case, RAM saving has to be enabled, otherwise you will loose all your work, as stated in the article.
Best regards.
HrastProgrammer
