Re: 17BII+ wobble Message #6 Posted by Ryan on 14 Apr 2010, 11:45 a.m., in response to message #1 by Ryan
Thank you, all.
It seems the rubber feet are perfectly molded into depressions in the bottom, so pulling it one direction or the other isn't possible. The outer column of keys also appear to be well within the supported area so the wobble seems to be from imbalanced rubber feet or a twisted case.
That said, my 12cp has the same problem and I ended up putting some tape on the bottom to keep it from rocking. The downside is that it lost its grip in that corner so now it tends to slide a bit!
I must be overthinking this. HP is sending crap out the door.
