Low-bat indication continuously on Message #1 Posted by Johannes Trepte on 12 Apr 2010, 11:38 a.m.
Hi, I have an HP-21 calculator which I had in use until a few years ago. There were never any defects, except for several replaced battery packs. Because it "ate" Ni-Cads, I used it with the mains adapter most of the time, which in turn damaged the batteries quickly.
My question: Even with new cells, the "low battery" indication (inverted decimal points) is always on. I would like to fix this, because I really like the part. Still perfect for every day work, no key bouncing at all ...
Has anyone experienced the same effect? Are there any schematics of the vintage HP calculators available, which could help to find the problem?
