Re: 9114B Battery Replacement? Message #3 Posted by Vieira, Luiz C. (Brazil) on 11 Apr 2010, 5:59 p.m., in response to message #1 by 聲gel Martin
Ola, 聲gel; 盧omo est嫳?
I once had to replace the battery that came with the HP9114B I have. At the time I tried finding a replacement, I found only a 1.3Ah battery against the 2.4Ah that came with the unit. Here you can see the pictures I took when testing the batteries (pictures were edited: cut and resized)
Considering that the smaller unit would provide shorter working periods, I tested it and it worked well. I actually avoided using it without the charger, as stated in the 9114B manual, so I thought that the worst case scenario would be the battery not providing enough peak current, like when the main driver motor started spinning the disk. I had no problems working with the 9114B with it for a while, and after the new replacement was delivered I replaced it. Have been using so far, for about two years.
Hope this helps a bit.
Luiz (Brazil)
Edited: 11 Apr 2010, 6:03 p.m.
