Applied Stats Solutions 1 and 2 documentation Message #1 Posted by David Airey on 7 Mar 2010, 3:00 p.m.
I was trying to find PDF copies of the Applied Stats 1 and 2 Solutions documents that reportedly contained some of the following program. (Not the Test Stats Book or Business Stats book.) Does anyone know where a copy might be found? I've been in contact with Tony Duell. Thanks.
ONEST : One Sample Test Statistic for Mean : Test Stats Solution Book
CORRTS : Test Statistic fr Correlation Coefficient : Test Stats Solution Book
DIFFPRP : Differences Among Proportions : Test Stats Solution Book
BEHRENS : Behrens-Fisher Statistic : Test Stats Solution Book
KRUSKAL : Ruskal-Wallis Statistic : Test Stats Solution Book
MNSQD : Mean-Square Successive Difference : Test Stats Solution Book
RUNTEST : Run Test for Randomness : Test Stats Solution Book
INTCLSS : Intraclass Correlation Coefficient : Test Stats Solution Book
FISHTST : Fisher's Exact Test for 2*2 Contingency : Test Stats Solution Book
BARTLTT : Bartlett's Chi-Square Statistic : Test Stats Solution Book
MANNWHT : Mann-Whitney Statistic : Test Stats Solution Book
KENDALL : Kendall's Coefficient of Concordance : Test Stats Solution Book
INTCONF : Mean and Confidence Interval : Applied Stats 1 Solution Book
HISTNRM : Histogram Normality Test : Applied Stats 1 Solution Book
ECHIND : 2 Independant Samples F & T Tests : Applied Stats 1 Solution Book
ECHPAIR : 2 Related Samples T Test : Applied Stats 1 Solution Book
ANVA1 : Single Classification ANOVA : Applied Stats 1 Solution Book
ANVA2 : Randomized Complete Blocks ANOVA : Applied Stats 1 Solution Book
ANVA3 : Latin Square ANOVA : Applied Stats 1 Solution Book
STAT8 : Comparisons Among Means : Applied Stats 1 Solution Book
ANVA5 : Nested ANOVA : Applied Stats 1 Solution Book
ANVA6 : Two-Way ANOVA : Applied Stats 2 Solution Book
ANVA7 : 3-Factor ANOVA : Applied Stats 2 Solution Book
ANVA8 : Factorial Experiments : Applied Stats 2 Solution Book
PMCORR : Product Moment Correlation Coefficient : Applied Stats 2 Solution Book
LINREGR : Linear Regression : Applied Stats 2 Solution Book
ANCOVA : Analysis of Covariance : Applied Stats 2 Solution Book
RANKTST : Non-Parametric Rank Test : Applied Stats 2 Solution Book
FREQTST : Non-Parametric Frequency Test : Applied Stats 2 Solution Book
SMOOTH : Forcasting using Exponential Smoothing : Business Stats Solution Book
SEASVAR : Monthly Seasonal Variation Factors : Business Stats Solution Book
MULTLR : Multiple Linear Regression : Business Stats Solution Book
NORMDST : Normal & Inverse Normal Distribution : Business Stats Solution Book
TDIST : T Distribution : Business Stats Solution Book
FDIST : F Distribution : Business Stats Solution Book
STAT2V : Basic Statistics for 2 Variables : Business Stats Solution Book
MOVAVG : Moving Average : Business Stats Solution Book
GOMPRTZ : Gompertz Curve Trend Analysis : Business Stats Solution Book
BRKEVEN : Break-Even Analysis : Business Stats Solution Book
LRNCURV : Learning Curve for Manufacturing Cost : Business Stats Solution Book
DEMAND : Price Elasticity of Demand : Business Stats Solution Book
