Re: HP-97 printer paper feed cam shaft Message #6 Posted by Ignazio Cara (Italy) on 9 Mar 2010, 4:36 a.m., in response to message #5 by Ed Sowell
Hi Ed,
I hope I understood your questions.
To the first, yes, the support is embedded on the rubber. Today evening, when at home, I will upload other more detailed images of the cilinder without the rubber, from diffrent view angle.
To the second question, it's very trivial to take apart the cilinder from the shaft. You must push the pin of the shaft against a strong surface, holding the cilinder tightly. I will show the way with a photo as well.
I hope to be helpful, for now.
Take care
Ignazio
