Re: HP38G/39G/48SX/48GX./49G Emulator now availble for iPhone/iPod Touch Message #4 Posted by Eric Smith on 14 Feb 2010, 12:23 p.m., in response to message #3 by Egan Ford
I'll do that. It doesn't meet the GPL license requirements, though:
3. You may copy and distribute the Program (or a work based on it, under Section 2) in object code or executable form under the terms of Sections 1 and 2 above provided that you also do one of the following:
a) accompany it with the complete corresponding machine-readable source code, which must be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
b) Accompany it with a written offer, valid for at least three years, to give any third part, for a charge no more than your cost of physically performing source distribution, a complete machine-readable copy of the corresponding source code, to be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
c) Accompany it with the information you received as to the offer to distribute corresponding source code. (This alternative is allowed only for noncommercial distribution and only if you received the program in object code or executable form with such an offer, in accord with Subsection b above.)
Option 3 is not applicable to m48+ because it is sold commercially, and not applicable to m48 because there is no upstream party that can provide the "corresponding source code". Note that all three options require that something actually be provided with the binary distribution, if only a written offer, which could be on the About page in the application.
