Re: HP-15C Enter Key Behaviour Message #2 Posted by Vieira, Luiz C. (Brazil) on 5 Feb 2010, 6:33 a.m., in response to message #1 by Timo
Hi, Timo;
I have disassembled some Voyagers and I actually pressed the lower metal disk under the ENTER key while the calculator was turned ON, both in normal (RUN) and program mode. I do not remember observing any reaction at all, and pressing only the upper disk, the one that is actually pressed when the ENTER key acts, provides necessary action. You can see in the picture how I managed to make them work outside the case...
Click to enlarge
Taken from Randy´s post (link you shared): Quote: The rubber sheet between the snap discs and the keys gets holes worn through the rubber from the key pin that pushes on the snap disk. This results in keys that are lower than surrounding key. They otherwise work okay, they just don't have the correct or same physical travel as the others. This is most common on the right hand side of the keyboard, i.e. the heaviest use keys (0 and . seem to go first).
I have an HP15C, bought new in the 80´s, and both [g] and [STO] keys have this problem: no keybreak (and no 'snap' feeling) the other keys have. But they work pretty fine once you press them the same way as the other keys.
I sincerely would not care much about it, but this is only the way IO see it.
Cheers.
Luiz (Brazil)
Edited: 5 Feb 2010, 6:34 a.m.
