Re: 41Z Keyboard Overlay - The Final Cut Message #6 Posted by 聲gel Martin on 15 Dec 2009, 9:27 a.m., in response to message #5 by Egan Ford
Hi Egan, yes you need to assign the function ZKBRD to the Sigma+ key - that enables the complex keyboard as per the overlay.
Printing the Z complex stack level is done by default on start-up. I don't have a printer and obviously neither does V41 but the behavior should be consistent. The rom works well in the real machine as well.
four complex stack levels are: U, V, W, Z (from top to bottom).
Complex level Z corresponds with the real stack Y (Imaginary part) and X (real part). Note that real Z, T are just scratch, as they're not "reliable". All is done in the complex stach, in a dedicated memory buffer.
Best wishes
Edited: 16 Dec 2009, 12:41 a.m.
