Help - broken HP-25 Message #1 Posted by Paul Dale on 16 Sept 2009, 7:57 a.m.
I've got a HP-25 that is broken and I'd like to fix it if possible.
The battery pack had some corrosion and the contact had some too. I've scraped this off and now the contact is nice and shiny. I've also rebuilt the battery pack, however further tests have been done using a small bench top power supply clipped to the battery contacts (polarity has been observed at all times) while the back is off the calculator.
Initially, the calculator was drawing about 100mA when switched on but without any display.
Okay, open it up carefully and reseat the main circuit board. Now the display shows '8' in random positions. Most typically at the right end but sometimes in other places and sometimes several (2 or 3) at once. No keys respond and the program/run switch does nothing either.
Pull it apart again and I don't find anything obviously wrong. I gently spread the between board connections a little to hopefully improve contact. Reassemble and now nothing. No power draw when on or off.
Does anyone have any suggestions as to what I broke and what the original problem was?
I don't have any for parts Woodstocks :-( I've got a working HP-21 which I could extract parts from but would prefer not too since it works.
I'll take this into work tomorrow and check for bad solder joints under the microscope.
So anyone have an idea on any other avenues to follow?
- Pauli
