Re: If I do this... Message #19 Posted by Maximilian Hohmann on 16 Sept 2009, 4:20 p.m., in response to message #18 by Pal G.
Quote: However, I believe freight jets fly higher than passenger jets (but not military jets!), so if one can time it right, and have an altimeter attached to I/O, one might get his/her calculator higher than a 747, while not carrying the device.
Most freighters are converted airliners that have the same airframe and powerplants as the passenger version and therefore identical performance values. Typical service ceilings of these aircraft are between 41,000 and 43,000 feet, independently of their configuration. The altimeter in your freighter however will not read more than 8,000 feet because the cargo holds are pressurised!
If you want your calculator taken to higher altitudes, you either put it on board of a Space Shuttle or Soyus spacecraft, a military fighter jet or a business jet. Even "my" (my bosses to be precise, but I get paid for flying it) little Citation reaches 45,000 ft. (Others like Learjets and Gulfstreams go above 50.000ft.) And we have an unpressurised baggage compartment, so your altimeter will actually read that figure. Some of my HP calculators have been there already - but without an altimeter attached to prove it...
And regarding the subject: If anyone wants to reapeat the experiment, _please_ get the necessary permissions from the relevant aviation authority. A one-Kilogram box with equipments can cause millions (Dollars/Euros) worth of damage to an aeroplane and endanger hundreds of people on board!
Greetings, Max
