Re: Toward a more user-friendly Forum Message #10 Posted by Kevin Brown on 12 Sept 2009, 2:13 a.m., in response to message #7 by Bart (UK)
In my opinion all it needs is a better search Forum search engine. Then we could easily find threads on all of Martin's subjects.
BTW, I know there was a thread on forum searchability recently but I couldn't be bothered to use Google to search for it as it doesn't always work (e.g. sometimes the links don't always work when it's recently moved into the archives).
It doesn't need just a better search engine: it also needs to ditch the concept of archives.
Really, a thread should be a continuous conversation until people stop posting to it. With the archive system, you lose a lot of context whenever messages are archived.
If you want to achieve the same thing as viewing threads as if they started on a given day, the forum software should be able to achieve that relatively easily, but you should always be able to painlessly view prior messages if you so desire.
I've always wondered why we have the archiving thing going when the amount of disk space required by the entire history of this forum is probably a tiny fraction of a single modern hard drive...
