De-allocating memory locations on HP-35s Message #1 Posted by Paul Kleinkramer on 23 Aug 2009, 8:33 p.m.
Hi!
I'm getting acquainted with my new 35s and finding the transition from my daily driver, a 20s, pleasant; and the return to RPN very refreshing! I won a 41CX in a college design contest in 1989 and became hooked on HP. I do miss that calculator...
While getting to know my new 35s, I allocated the full 801 variable locations with indirect (i). I thought this was fine until I discovered the hard way, (memory full), that the amount of memory left for programming was trivially small. A calculator reset solved the problem but subsequent reading, plus trial and error, has not turned up a way to de-allocate memory once its assigned to variables.
Any ideas from those who understand this better than me?
Thanks so much! Great fourm,
Paul
