Re: HP 41CV repair - constant Memory Lost message Message #2 Posted by Geoff Quickfall on 20 Aug 2009, 7:15 p.m., in response to message #1 by Nigel Bamber
This has happened with my half nuts but I am sure it can happen to the fullnut.
Hopefully it is a software, not hardware problem.
It took 48 hours for my two 41CXs to drop the MEMORY LOST lock up. Here is what I did and I am sure others have their methods, but do it in this order and move to the next step if the previous step failed:
1 try a master clear, ON+CLX
2a if you have a card reader
b install it
c try to run a card.
3a remove the batteries
b short the far left to far right battery contacts
c reinstall batteries
d test with the ON+CLX
4a remove the batteries
b reverse their positions in the holder,
c install pack with reversed batteries
d hold the ON key ON for ten seconds then release
e reinstall batteries
f test with the ON+CLX
5a remove the batteries
e leave calculator OFF over night.
f reinstall batteries
g test with the ON+CLX
These methods were first developed with Synthetic applications, which when handled incorrectly caused a freeze. The freeze was carried even when the calculator was OFF by the capacitor which retains the last memory condition of the software.
The above, all attempt to zero the capacitor leaving the calculator in its original state.
Mine took me to step 5 and I had written both of them off until two days later when I got back from a trip. I picked one up for the curiosity fully expecting it to remain in the OFF condition or with the frozen MEMORY LOST. Put in a battery pack, switched it on and VOILA! it worked. Tried the second machine and it worked!
Be warned, some have reported that it took up to a week without the batteries to unfreeze the calculator.
Hope this helps, Geoff
Edited: 20 Aug 2009, 7:18 p.m.
