HP-41 question Message #1 Posted by Monte Dalrymple on 9 Aug 2009, 9:39 p.m.
Does anyone have the physical specifications for the daughterboard in a fullnut?
In particular, I'd like to find out the exact location and sizes for the two holes in the circuit board that hold it in place over the zebra-strip connectors.
By my measurement, looking fron the top of the board and starting
on the left side, I have 15.5mm to the edge of the first hole, a 4.5mm hole, 28mm to the edge of the second hole, another 4.5mm hole and then 14.5mm to the other edge of the board.
Obviously there's some play allowable... but I don't want to much play when mounting a board. And I _really_ don't want to end up with holes 0.1mm too small or 0.1mm too close together.
Thanks,
Monte
