Re: Hp50g Serial Number Message #2 Posted by Mike Morrow on 5 July 2009, 10:16 p.m., in response to message #1 by Quan
The same thing can be seen on the HP49g+. They are always different, though the time differential between them seems to vary significantly. On my HP49g+, the internal number is three weeks later than the external. On my HP50g, the internal number is three weeks before the external.
On the HP49g+ and HP50g, if the Development Library has been activated (set system flag -86, then warm restart with a ON+F3), the SERIAL command will be available. When executed, it returns the internal serial number.
