Does the HP-IL module for the HP-41C break the loop? Message #1 Posted by Klaus on 17 June 2009, 10:37 a.m.
does the HP-IL module for the HP-41C break the loop when it is unplugged or the HP-41C is powered off?
I have a HP-IL device with a built-in HP-41C IL-Module. Since I know nothing about the device, I want to hook up a HP-71B to get the device id using DEVID$(1). Simply connected (via the 2 cables, so the loop should be complete with just these three devices [HP-71B, device, HP-IL module]) to the device, the HP-71B takes a long time (about 30 seconds), then displays "HP-IL Error: loop broken". Is this because the IL-module does not close the loop if the HP-41C is turned off?
I have a HP-41CX for using the device, however, I don't see how I could obtain any information about the device without the IL-extension module or the I/O module. So I want to try it with the HP-71B.
