Re: Woodstock glue? Message #4 Posted by Geoff Quickfall on 2 Apr 2009, 8:33 p.m., in response to message #1 by james summers
I have used liquid plastic cement and clamps.
1. clean up the edges
2. rough up the surfaces that are to be glued with 400 grit
sandpaper
3. apply glue to both sides and then place pieces together
4. clamp until dry, give it an hour or so
This will give a permanent bond to the woodstock battery pack.
Cheers, Geoff
