HP 20b: test-menu Message #1 Posted by Thomas Klemm on 31 Mar 2009, 6:05 p.m.
Recently I wanted to change the display mode on my HP 20b to show all digits but I did't remember how to do that.
I didn't find the answer in the small booklet that came with the calculator so I searched online where I finally found it in the training module
Operating modes, clearing options and error messages.
Why not in Interest rate conversions or Hyperbolic functions I wondered.
However I was happy to find what I was looking for and of course it suggests itself to use FIX = -1 for that in the Mode-menu
whereas you have to use the dot in the shift-shift-digit-shortcut, if you know what I mean.
The important thing is always: be consistent!
For a moment I remembered a recent post of John H Meyers on comp.sys.hp48 where he stated:
In 48GX, the STAT DATA menu (...) contains a [\GSDAT] label.
The left and right shift keys cause that menu key
to generate STO\GS and RCL\GS commands, respectively
(best seen when editing in PRG mode).
This is similar to how STEQ and RCEQ commands are generated
by the [EQ] label in the SOLVE ROOT menu (menu 75 on "G" series).
A number of other menus generate useful complete structures
when shifted, e.g. the various labels in PRG BRANCH
(menu 23 in "G" series):
LS IF -> IF THEN END
RS IF -> IF THEN ELSE END
Try all the others and see!
Obviously there were times people at HP designed things very clever.
But the worst thing of the Mode-menu is pressing the [=] button until the number
of digits you want is displayed. The stack is cluttered with all the numbers you
went through and your worthy results are lost. You should have known better not
to use the [=] button!
However all this has nothing to do with the subject but that's how I found the
lines with the description on how to perform a MEMORY CLEAR:
The "master clear" of the HP 20b is accomplished when the following sequence is executed:
- press and hold [ON/CE]
- press and hold [N]
- press [FV]
DO NOT DO THIS IF YOU WANT TO KEEP ANY INFORMATION THAT IS IN YOUR CALCULATOR.
I can assure you that you will not loose any memory. I tried it several times.
And then I tried [ON/CE] [N] [Amort] as I would do on most other HP-calculators and
All Reset
appears.
Then I tried the other button [PMT] next to it on the left since you knewer know, right?
And alas we enter a test-menu:
- Tst Screen
- Tst Keyboard
- Checksum
- Tst Battery
- SW Version
- (c) Copyright 2008 HP Dev. C., L.P.
- TSys
In the screen-test you can press any key and the anounciators and the display will be shown
which is always funny to do. So after a while playing with that I entered the keyboard-test
which was a big mistake: first you may think you have to press them in a specific order but
then you might try to produce an error and skip one and nothing happens and then you start
wondering which of the keys will bring you out of this menu and at the latest now you're
relieved somebody at Apple invented the paperclip-trick.
However if you skip keyboard-test and succed to exit the menu you will find that this is yet
another method to set FIX = 3 on this amazing machine.
No wonder the ratings in the
customer reviews are so bad.
Kind regards
BTW: Any idea what this TSys-menu is for?
