Is It Possible to "Overload" HP-48G+ Memory? Message #1 Posted by Ed Look on 28 Mar 2009, 9:29 p.m.
I tried to use the <left-shift> MEMORY function to look at the contents in my 48G+ when I got an "Insufficient Memory" message displayed across the top of the screen instead of file or object names.
Initially I got the same message when I tried to redisplay the clock, as it disappeared from the top line when I turned on the unit, and when I tried to use the <left-shift> MODES function. I tested its batteries, and they were next to totally kaput, so I put three fresh AAA 1.5 Duracell batteries in to replace them.
The clock came back, I could access the MODES menu, but MEMORY still gives the the "Insufficient Memory" message.
I *COULDN'T* have maxed out the 128K of RAM, right??
Or, is something wrong on the circuit board?
